Ler kilometros pelo VAG
Alguém me sabe dizer os passos para conseguir ver os KM do carro através do vag?
Cumprimentos
Re: Ler kilometros pelo VAG
so da para ver com a versao 607 ou superior
mas ficam aqui umas imagens exemplificavas
Obrigado, ja vou testar :cool:
boas
tenho vag 908 e seguindo o que dizes aqui da-me erro ,eu sei os km que o carro tem comprei novo mas de qualquer forma queria ver como funciona.
o carro e um fr my09
Uploaded with ImageShack.us
ricardo
Local: lisboa
so consigo ver os km fazendo um scan
esta e aparecer aqui um erro 0010 mas nao noto qualquer problema no carro sera assim
Sunday,02,May,2010,15:36:12:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ9R030482 Mileage: 13460km/8363miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 018 GP HW: 03G 906 018 GP
Component: R4 2.0l PPD1.2 G 2281
Revision: --H52--- Serial number: SEX7Z0H831H0GC
Coding: 0050072
Shop #: WSC 06401 785 00200
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 143B6012092500FA280F06EC901B00423400
Shop #: WSC 04941 000 00000
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000004934092
Coding: E1880F2F00041000431D00000000000000017F075C40000C000000000000
Shop #: WSC 06402 785 00200
Part No: 1P0 955 119 B
Component: Wischer 290708 022 0601
Coding: 00056208
Shop #: WSC 06402
Part No: 1P0 955 559
Component: REGENLICHTSENSORH04 0090
Coding: 00152622
Shop #: WSC 06402
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A02 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPJDFLA%
Coding: 0012338
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0002042
Part No: XXXXXXXXXXX
Component: E0221 001 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 827 C
Component: KOMBIINSTRUMENT VO3 0450
Coding: 0002101
Shop #: WSC 15003 784 55581
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K089090719
Coding: E9807F060002020202
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VO3 0450
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000288988611
Coding: 0004272
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.142 H08 1901
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005283CC7F7F068F0F60084F86307C80
Shop #: WSC 00018 261 05504
Part No: 1P0 951 171 A
Component: Innenraumueberw.010 4974
Coding: 00000000
Shop #: WSC 00018
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 24
Reset counter: 41
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000057988617
Coding: 0004272
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0007
Coding: 0040422
Address 62: Door, Rear Left Labels: None
Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003365965
Coding: 0000144
Address 72: Door, Rear Right Labels: None
Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003363895
Coding: 0000144
End ---------------------------------------------------------------------
ricardo
Local: lisboa
a mim da o mesmo erro so no modo autoscan é que consigo ver os kilometros
ricardo Escreveu:boas
aparece-me precisamente o mesmo... :nop:
Nem todas as centralinas permitem ver os Km's
Como já responderam nem todas as centralinas deixam ver o km com VAG-COM e os kms que aparecem no scan são os do mostrador do carro (conta-km do carro).
Abraço.
branzelo Escreveu:Como já responderam nem todas as centralinas deixam ver o km com VAG-COM e os kms que aparecem no scan são os do mostrador do carro (conta-km do carro).
Abraço.
os km's da centralina são sempre diferentes do conta km's, mesmo que nao tenha sido mexido por causa da margem de erro que se nao me engano é de 5%
mas quando sao mexidos o mais certo e teres no conta km's 100.000km e na centralina 150.000km isto é um exemplo
rfsmarques Escreveu:Nem todas as centralinas permitem ver os Km's
Exatamente isto....
E por mais o teu cabo so da pa ver pelo q vejo nas imagens as EDC15..ha os quem lêm EDC 15 e 16...
Abrc 8)
Boas eu tenho o vag 10.6 e ja testei em varios carros e aparece-me o mesmo erro.
So no scan é que consigo ver.
Curiosamente num seat nao bateu certo com os do mostrador... falhou 6km.
A mim também só aparece no AutoScan, com uma diferença de 6km.
Isto será do que?
Alguém pode ajudar?
Miggz Escreveu:Boas,
Isto será do que?
Alguém pode ajudar?
Não é de nada, pode existir uma diferença de 5% para baixo ou para cima, como já foi dito... fora disso é que foi mexido!
