Boas amigos.
Comprei um cabo vag-com porque aendeu-me a luz do motor.
O que obtive foi isto:
Thursday,10,February,2011,22:28:57:36838
VCDS Version: Release 10.6.2
Data version: 20101123
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: VSSZZZ5PZ8R023155
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 018 DJ HW: 03G 906 018 DJ
Component: R4 2.0l PPD1.2 G 4347
Revision: --H42--- Serial number: SEZ7Z0G3878151
Coding: 0050072
Shop #: WSC 15004 784 175268
VCID: 70E4CC445CF9059C
1 Fault Found:
001139 - Exhaust Pressure Sensor 1 (G450): Signal too High
P0473 -- 006 -- Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 1
Fault Frequency: 172
Reset counter: 40
Mileage: 139411 km
Time Indication: 0
Date: 2000.00.00
Time: 17:07:04
Freeze Frame:
RPM: 768 /min
Torque: 56.0 Nm
Speed: 42.0 km/h
Voltage: 14.13 V
Mileage: 410 km
Text: 384 C
Pressure: 1597.5 mbar
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006898
Shop #: WSC 04941 785 00200
VCID: 73EEC3482DEF3E84
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 F
Component: ClimatronicPQ35 011 0602
Shop #: WSC 00000 000 00000
VCID: 336E03486D6F7E84
Segundo dá o erro..tens o sensor da pressao dos gases demasiado elevado.
Possivelmente está a dizer q tens gases acima do valor normal q deverias d ter.
tens FAP? Tiras-te catalizador? Panela traseira?
Boas.guiZmo Escreveu:Segundo dá o erro..tens o sensor da pressao dos gases demasiado elevado.
Tenho FAP, mas não sei se tem catalizador, pois cheira um bocado a gases o carro.
Já comprei assim á algum tempo, mas só agora acendeu a luz do motor.
Vê se a FAP está a fazer bem o seu trabalho.
Como não percebo nada disso?guiZmo Escreveu:Vê se a FAP está a fazer bem o seu trabalho.
Aliás acabei de fazer mer** agora no sitio dos km tenho numeros e letras (5322rA) e o radio deixou de funcionar e nao tranca com o comando.
Bonito....
Alteraste alguma coisa com o vag com antes de isso acontecer?Tiago Valente Escreveu:Como não percebo nada disso?guiZmo Escreveu:Vê se a FAP está a fazer bem o seu trabalho.
Bonito....
Aco que não, apenas tive a ver os paramentros das Applications...Ressurras Escreveu:Alteraste alguma coisa com o vag com antes de isso acontecer?Tiago Valente Escreveu:Como não percebo nada disso?guiZmo Escreveu:Vê se a FAP está a fazer bem o seu trabalho.
Bonito....
É estranho mudar-me os km para 5377rA
Alguma coisa se passou... Eu não entendo muito de vag com, espera a ver se alguém mais entendido te dá uma ajudaTiago Valente Escreveu:Ressurras Escreveu: Aco que não, apenas tive a ver os paramentros das Applications...
Desculpa que te diga mas se nao sabes trabalhar com o vag nao devias de mexer ainda aarranjas problemas mais serios aqui deixo um Manual super completo sobre como isso funciona ve la se te safas..
http://www.leonclubpt.com/forum/viewtop ... 43&t=23023
Resolvido....agora só o erro do sensor de pressão de escape g450 =S, ninguem com os 2.0 170cv´s já teve este problema?Nuno Tomás Escreveu:Desculpa que te diga mas se nao sabes trabalhar com o vag nao devias de mexer ainda aarranjas problemas mais serios aqui deixo um Manual super completo sobre como isso funciona ve la se te safas..
Da-lhe umas gazadas e tenta apagar depois a ver se volta a aparecer....Tiago Valente Escreveu:Resolvido....agora só o erro do sensor de pressão de escape g450 =S, ninguem com os 2.0 170cv´s já teve este problema?Nuno Tomás Escreveu:Desculpa que te diga mas se nao sabes trabalhar com o vag nao devias de mexer ainda aarranjas problemas mais serios aqui deixo um Manual super completo sobre como isso funciona ve la se te safas..
